1941 h
pete
10-15-2003 18:38:19
just got my head rebuilt and ready to start
putting the engine back together. do i put any
oil in the governor box. i took the cap off and
saw it was dry.---once i re-assemble everything
how do i not cross the wiring for starting purposes.---also any advice on re-welding the
two studs on the bottem of the radiator as they are missing...1941 h
Farmer Bob
10-15-2003 19:16:30
 Re: 1941 h in reply to pete, 10-15-2003 18:38:19
The governor will be oiled from the engine running. Look at the right side of the block and see the firing order of 1-3-4-2. Rotate the engine until the #1(Front) cyl. is at TDC and check to see the location of the rotor in either your mag or dist. The corresponding post on the cap should be wired to your #1 spark plug. Then go around the cap in Clockwise direction to wire the rest of the plugs (1-3-4-2) and hook up the coil wire into the center post on the Dist/Mag cap.
Just buy two new studs and screw them into the holes on the bottom of the radiator. Available at your local Cas NH dealer or any good auto parts/hardware store. THink originals were 3/8" NC thread on one end and NF on the other. They usually had castelated nuts and cotter keys through the bolster end. Don't forget the rubber pads for the radiator to sit on.
Wayne Swenson
10-15-2003 21:09:11
 Re: Re: 1941 h in reply to Farmer Bob, 10-15-2003 19:16:30
HOLD THE PHONE!!!
There is a 50-50 chance that your description is correct.
The mechanic must ALSO verify that #1 cylinder is coming up on compression, not exhaust.
Either put your thumb in the #1 spark plug hole and have someone hand crank until you feel compression or watch the rocker arms as you crank, #1 intake will open & close then with 1/2 revolution of the crank you should be at TDC (top dead center).
Locate the TDC mark on the front pulley and align it with the pointer. Now you can look at the distributor rotor to see which wire goes where. From the operator's position, # 1 is usually around the 2 o'clock position.
PS: the points should be set to just begin to open as the TDC mark passes the pointer.
Easy, isn't it??
