live hydraulic on super M
David
10-15-2003 20:44:08
Whats the best way to put live hydrualic on a super m and where might you purchase this pump?
Stan(VA).
10-16-2003 05:12:48
 Re: live hydraulic on super M in reply to David, 10-15-2003 20:44:08
As I assume you have already found out, the Super M came in two versions (early and late or): Stage I with the old style belly pump; and Stage II with live hydraulic pump that mounts in front of the distributor. So you need a pump from either a stage II Super M or a Super MTA.
Next you need to decide what to use as a reservoir. M&W had a kit to replace the pump cover on the belly pump with a flat plate and plumb that as the reservoir, you could also buy the factory reservoir that mounts under the gas tank. If you choose the latter though, be aware you will need to relocate the battery under the seat (buy new battery box and seat suspension), and fabricate a new mount for your starter switch and choke control rods.
As far as sources, try a salvage yard or find a puller that want's to reduce weight on his Super M and trade all the parts with him. He will want your sheet metal rear fuel tank mount and your distributor drive housing.
Stan(VA).
MARSHALL
10-16-2003 13:33:19
 Re: Re: live hydraulic on super M in reply to Stan(VA)., 10-16-2003 05:12:48
I PUT LIVE HYDRAULICS ON MY SUPER M (1953) BY TAKING A PUMP OFF FROM A 450. I REMOVED THE BELLY PUMP AND MADE A COVER PLATE BY USING THE GASKET AS A PATTERN. THAT MADE FOR AN ADEQUATE SIZE RESERVOIR.
