F-20 fuel tank
Dave@NY
10-16-2003 03:14:43
Got in a bunch of parts recently a tank for F-20.Looking at it I see that it has 2 outlets in the bottom of main tank. The extra one is outboard of the fitting that the strainer would thread into. It appears to be the same kind of fitting and has the same 4 small spotwelds[??]and soldered in just like the other one.In other words it looks like a factory job, or someome did an extra nice job of adding this in. Never seen this before, why would this extra fitting be there??
John Walls
10-16-2003 16:39:48
 Re: F-20 fuel tank in reply to Dave@NY, 10-16-2003 03:14:43
Do you want to sell that tank, Dave? I need one. Mine is bent.
Nebraska Cowman
10-16-2003 16:52:14
 Re: Re: F-20 fuel tank in reply to John Walls, 10-16-2003 16:39:48
John email me I have some tanks.
Nebraska Cowman
10-16-2003 03:44:00
Yes Dave, that fitting is standard on F20 tanks. I assume it is for a drain. The ones I have seen have a square headed pipe plug instaled.
Dave@NY
10-16-2003 17:55:32
 Re: Re: F-20 fuel tank in reply to Nebraska Cowman, 10-16-2003 03:44:00
Intresting! I have a pair of '37s and neither one of these have the extra fitting for a drain.Was this something particular to certain years??
Ron in Nebr
10-16-2003 20:52:51
 Re: Re: Re: F-20 fuel tank in reply to Dave@NY, 10-16-2003 17:55:32
My '36 F-20 has that drain, and yep, just like NE Cowman said, it has a square-head pipe plug in it.
Dave@NY
10-17-2003 02:40:16
 Re: Re: Re: Re: F-20 fuel tank in reply to Ron in Nebr, 10-16-2003 20:52:51
Something else to add to my list of things to look for next time I get to a tractor show.Kind of like-how many F-20's you ever seen without the belt pulley assembly? Think I've only ever seen one at the shows.Must have been a factory or dealer delete order? Farmer must have had nothing that required belt power,or had something else to provide it.
