Plow Depth Question
Justin
10-16-2003 16:41:40
I have a question on plow depth on my 2 bottom plow. It seems like it isn't going very deep. I have both trips up all the way (to lower plow) and have the clutch engaged. It seems like the molboards don't go but a few inches deep and if there is any grass on the surface it catches and binds up into a mess and gets caught in front of the molboards. Shouldn't the molboards go down quite a ways? It does a good job where the beans were combined, but if there is any little trace of grass, it causes a big mess. What should I do?
Thanks
Hugh MacKay
10-16-2003 18:53:15
 Re: Plow Depth Question in reply to Justin, 10-16-2003 16:41:40
Justin: Sounds to me as though you have both items the other guys mentioned wrong. You need coulters and you need new points. When a plow point gets worn to the extent it is turned up on the end, it acts just like a sled runner, and will ride the plow right out of the ground.
Dick
10-16-2003 16:58:27
Are you using coulters to cut the grass ahead of the moldboard?
Nebraska Cowman
10-16-2003 16:49:04
how are your points? The tips need to be turned down slightly to give it "suck"
