super C carb still leaking
farmallsc
10-17-2003 16:14:29
my super C was leaking gas at the carb end of the pipe which goes from the air filter to the carb. i looked at it and the needle valve looked bad (is a carter UT) so thirty bucks ater ive put the new valve in, still leaks. the pipe is pretty nasty looking and i dont think is gonna last much longer but i dont wanna puta new pipe on because if the gas collects in the air filter and it backfires through the carb bad things will happen. what do i do, oh and when i pull the throttle all the way back the gas still leaks or was that just the gas in the carb? small amounts of gas are in the oil cup on the bottom of the air filter container. there is no oil in the cup (i dont know why should i fill it?)
CNKS
10-17-2003 19:27:51
 Re: super C carb still leaking in reply to farmallsc, 10-17-2003 16:14:29
You have an oil bath air cleaner, no oil in the cup, you get dirt in the engine. With oil in the cup, the dirt is trapped at the bottom of the cup due to centrifugal force. You sure the float doesn't have a pin hole in it? Assuming your needle and seat are ok, the float is either set wrong, or is hanging up on the side of the bowl. Sometimes it is hard to completely stop the leak. If you "fix" it and it still drips, turn off the fuel when you stop the tractor, a small leak should stop with the tractor running.
farmallsc
10-17-2003 16:45:08
i forgot to say the floats ok
Dave_Id
10-18-2003 08:18:38
 Re: Re: super C carb still leaking in reply to farmallsc, 10-17-2003 16:45:08
Like CNKS said, make sure the float isn't hanging up, I had this same problem with the Carter UT carb on my Super C.. After removing and installing a dozen or so times, I finally squeezed the float together a little, and it stopped leaking.
