H lift-all oil amount
john
10-17-2003 17:56:58
I want to use my H to run a 2 1/2 x 8' hyd. cylinder, my Lift-all is full on the dipstick, should I add a little more oil or is a full Lift-all enough? Thanks!!
Nebraska Cowman
10-17-2003 18:03:26
 Re: H lift-all oil amount in reply to john, 10-17-2003 17:56:58
just try it. You can run them over full if you have to. Just don't fill it with the cylinder extended because it will squirt oil out the breather hole when you retact it.
