IH Hydraulic problem
Mike in Vermont
10-17-2003 20:32:15
I have an intermittent hydraulic problem with my IH 2444 (basically the same tractor as a 444 but the utility model). This machine has two hydraulic systems. The one running the loader & backhoe works fine but the power steering/three point hitch system quits working from time to time and then comes back on line for no apparent reason. I'm thinking it's not a pump problem because I can't see how that would be intermittent. There is a flow divider that could potentially affect these systems but I don't know much about it. Any expertise would be greatly appreciated. Thanks, M.H.
Ben in KY
10-20-2003 06:37:36
 Re: IH Hydraulic problem in reply to Mike in Vermont, 10-17-2003 20:32:15
Have you checked/cleaned the suction screen ? It is the tube coming out of the right bottom front of the lift box.
Also the lift box has a stand pipe in it that overflows fluid into the tranny. There is a seal around this tube, if it goes bad the lift box res will empty and shutdown the engine mounted hydraulics.
