560 Gas wont charge battery PLEASE HELP
Big Red 1
10-19-2003 06:10:42
Battery wont charge off system,the generator has just been rebuilt professionally,the battery new and checks out and takes a charge off the charger,if I have some type of slow discharge any guesses?I dont know ifsystem was charging before I replaced it or not,as the tractor set out side for a good part of its life and took and had a generator rebuilt off a 460 and placed on this.
Any ideas?? as always thanks in advance
hal
10-20-2003 04:28:32
 Re: 560 Gas wont charge battery PLEASE HELP in reply to Big Red 1, 10-19-2003 06:10:42
if its a 12v generator, you need to polarize the fields in the generator. I replaced the voltage regulator on mine and I had to polarize it about 3 time to get it to finally charge. its been working great ever since.
Jerry
10-19-2003 23:06:48
Red:
Did you check your regulator for voltage output with a meter? If it is ok, then check to see if you're getting same volatge at the batt. If you have an AMP guage on the IP, you may want to check to make sure the guage is good also.
Jerry
Allan
10-19-2003 09:16:03
Hi,
Did you excite the field? How about the regulator? Is it pulling it in?
Allan
Gary
10-22-2003 06:40:27
 Re: Re: 560 Gas wont charge battery PLEASE HELP in reply to Allan, 10-19-2003 09:16:03
Make sure the voltage regulator is grounded. If the mounting bracket was taken loose under the fuel tank there might be dirt under the bracket
