Rear axle on Farmall A
Frank Zmigrodsk
10-19-2003 08:13:13
I need advice on removing the rear, driver's side axle, on my 1940 'A'. I have removed the wheel and the inside retaining nuts and washer but can't get the axle out. I have hammmered the wheel hub and it moves about 1/2 inch and then stops. It seems like the inner bearing is frozen to the axle as the bearing moves with the axle. How hard can I hit it without breaking something. Do I need to apply heat? Appreciate all suggestions. Frank Z.
Hugh MacKay
10-19-2003 13:15:57
 Re: Rear axle on Farmall A in reply to Frank Zmigrodski, 10-19-2003 08:13:13
Frank: Do you have the gear oil pan off the bottom of the final drive. When you mention about the axle coming about 1/2" my thoughts are you may have some wear in spline on axle and bull gear may be what is holding the axle If worn in the section of spline in the bull gear, that may be problem.
My thoughts are if it moves 1/2" the bearing must have moved some. I think I would remove the final drive from tractor, then you could suspend the final drive on it's side with axle hub down or up for that matter. Move the axle back and forth the 1/2" This should give you better view of what is sticking and where. With the use of a small punch try sliding bearing back the 1/2". With the final drive suspended on two blocks and axle hanging down you could use a brass punch or hardwood block to hammer on inner end of axle. Key here is not hit anything very hard. You may have to move it back and forth the 1/2" several times. A lot of patience is in order. Let me know how you make out.
