outlets on 41 h head
ole pete
10-19-2003 13:49:05
on the exterior of the head of my 41 ''h'' there is - 3/8 '' threaded hole , on
the back of the head , were does this tie in to. also the tubing coming off the top of the governor were does this tie in to.
rustyfarmall
10-19-2003 17:43:28
 Re: outlets on 41 h head in reply to ole pete, 10-19-2003 13:49:05
There should be a small tube coming off of the donaldson air cleaner, it connects to that hole. The tube coming off the top of the governor connects to a similar hole at the front of the head. This is all part of the crankcase breathing system, the two holes at either end of the head are then connected to each other by the tube that is installed roughly parallel to the valve rocker assembly, this tube will have one small hole drilled in it, to pull the gases out of that area.
ole pete
10-19-2003 18:42:56
 Re: Re: outlets on 41 h head in reply to rustyfarmall, 10-19-2003 17:43:28
thanks rusty farmall--what do i do if my breather has no hole to accept the tube from the rear of the head,
rustyfarmall
10-20-2003 04:53:18
 Re: Re: Re: outlets on 41 h head in reply to ole pete, 10-19-2003 18:42:56
I've never seen an H that didn't, do you possibly have the wrong breather?
Dave_Id
10-19-2003 21:30:54
Take a look at another H to see how it's plumbed, then copy it.
Dave_Id
10-19-2003 16:40:44
The hole in the back of the head may be a 1/8 NPT pipe thread which is a breather hole plumbed to the air cleaner... ????? Just guessing here
