Splitting the 300
Kelly C
10-19-2003 19:14:41
Well I guess its time to quit messing around with this 300. I had held out hope that I could get the motor going the easy way, but this has not worked.
I did get the #2 cylinder broke loose and I can get it to move down with the aid of a sledge hammer. Nothibg I have tried will make it move up in the cylinder.
It appears that I need to split the 300, Pull the motor, pull the crank to get it out of the way. Then beat the crap out of the pistons to get them out through the bottom.
sod
10-21-2003 08:31:28
 Re: Splitting the 300 in reply to Kelly C, 10-19-2003 19:14:41
Aren't you near Braham?
Did you see the note I posted about the auction in Hinckley?
good luck
sod
Kelly C
10-22-2003 21:19:16
 Re: Re: Splitting the 300 in reply to sod, 10-21-2003 08:31:28
Yup I live in Braham. Cant go to ant auctions for now.
I spent all my money all ready.
Guy
10-19-2003 21:44:57
Kelly, If I remember right, you can take the engine out of a 300 by removing one of the the side rails. I will do do some research on this and if I'm wrong, please jump in and correct me. Its alot easier than splitting the tractor. Anyway Kelly, you are probably about ready to give up on me stopping by, the duck hunting has been better this year than most and deer season is right around the corner. I have that hoist up north and if you think you may need it, I'll bring it home this fall.
Guy-up in the great north
Kelly C
10-20-2003 04:10:07
 Re: Re: Splitting the 300 in reply to Guy, 10-19-2003 21:44:57
Sure bring it by if you are not going to use it for a wile. I haven't purchased one yet.
My budget is all shot to heck any way as it is.
I put a extra $500 in that 400. $300 for a starter and $200 for the 3pt lift arms.
WIRED
10-19-2003 21:08:34
Well, it is more work, but far less fustrating when all done properly.
No substitutes for doing it right, and the short-cuts always create more work in the long run.
Split away! Get that digital camera out and document it for the rest of us!
R Marg
10-19-2003 20:00:03
have you tried to loosen them by putting turpentine in the cylinders and let it sit a day or 2 this has worked on all the engines I have tried it on
