300U hydraulics out
Dennis
10-20-2003 10:11:08
I was out raking with my 300U. It slowly stopped lifting the three point rake till it will not lift the rake at all. There is plenty of fluid in the reservoir. There is no new noises from the pump.
Any ideas? I have zero knowledge of hydraulics. thanks in advance.
Bill
10-20-2003 12:52:19
 Re: 300U hydraulics out in reply to Dennis, 10-20-2003 10:11:08
Well Dennis...You may have the dame problem I did. There is a screen in the hydraulic tank.
You will have to drain the tank, remove the seat and valves. The tank is the entire platform the seat sets on. Inside there is a cannister looking filter screen. Mine was so stopped up it sucked itself almost flat. I have to get another from a salvage tractor and clean it up.
The gasket and o-rings are still avaliable from IH. I hope that's all it is. That pump is expensive.
Denny
10-20-2003 20:50:05
 Re: Re: 300U hydraulics out in reply to Bill, 10-20-2003 12:52:19
I have a 300 row crop with similar problem, where is the screen on this tractor?
Van
10-20-2003 21:22:37
 Re: Re: Re: 300U hydraulics out in reply to Denny, 10-20-2003 20:50:05
Right below the hydraulic control levers on the right side, round cover with a 4 bolts in a square patern around the round part. Drain system first, then remove cover.
