charn-lynn power steering
Delbert
10-20-2003 11:53:59
I have a m farmall with a charlynn power steering that is leaking oil out the back of the steering motor. What i need to know is should i order a repair kit or can the o ring be replaced? Also if i replace the o ring are there gaskets or seals that should be replaced or can they be used over again? Need your expertize thank you very much. Delbert
K-Mo
10-21-2003 05:41:27
 Re: charn-lynn power steering in reply to Delbert, 10-20-2003 11:53:59
Force America (www.forceamerica.com) has kits. For the shaft o'rings, use "quadrings". They have multiple contact surfaces and do a better job of sealing.
K-Mo
Bob M
10-20-2003 12:17:39
You certain the oil's leaking out of the shaft seal and not coming from the hose manifold? The one on my SM leaked terribly when I got the tractor. Turned out the hose manifold had loosened up and one of the O-ring seals was partially blown out. Replaced the O-rings (found matching rings for $.10 apiece at Home Depot) and tightened the manifold back down - it hasn't leaked a drop since.
I understand there is a complete gasket and seal kid available for the Charlynn steering motor - Bates Corp stocks them. However I've never had one of these apart. I do know however you need to be careful taking it apart, and to put it back together with the parts oriented EXACTLY as before. Otherwise the PS won't work right when you are done.
