Super A or Super A culti-vision that's the ???
Gav-n-Tn
10-20-2003 19:09:28
In ordering decals for my Super A how can I tell if I have a Super A or a Super A culti-vision??What's the difference?Mine is a '52 model.Is there something on the tractor that is different or what.What's the criteria?
CNKS
10-20-2003 20:11:41
 Re: Super A or Super A culti-vision that's the ??? in reply to Gav-n-Tn, 10-20-2003 19:09:28
All offset tractors were cultivisions. There is no difference. However, I don't think any Super A's were decaled as such. The early Super A's had the curly "Super" over the A, and did not say cultivision. Your 1952 came with the white decal with the red Super above the red A, so that's what you should order. But, regardless, your tractor is a cultivision.
Hugh MacKay
10-20-2003 19:53:46
Gav: Nothing more than an advertising gimmick, some had it and some didn't. I will say it seemed more prevelant druing the mid 40s on both A and SA
Al
10-21-2003 05:27:01
 Re: Re: Super A or Super A culti-vision that's the in reply to Hugh MacKay, 10-20-2003 19:53:46
Technically, your 52 Super A should not have the "curly" Super A emblem, but the white circle with SUPER above the A in red. The change officially took place in '51 but it's possible later tractors got the curly decals until the old stock ran out. The "curly" Super A emblem did have CULTI-VISION in WHITE underneath the A, forming the bottom of the circle. When these decals were reproduced for the first time, CULTI-VISION showed up black, which is dead wrong. A good sign shop can make up the CULT-VISION in white letters for you cheap.
Also, your hood decal should say "McCORMICK," not McCORMICK-DEERING. They changed that in 49.
HTH
Al
CNKS
10-21-2003 18:12:10
 Re: Re: Re: Super A or Super A culti-vision that's in reply to Al, 10-21-2003 05:27:01
You are right! I have never seen a Super A with the early decal, mine has the white one, but a couple of pictures in Guy Fay's Letter Series book do show something in the bottom of the circle. Too small to read, and would not have seen it if you had not said so. Learn something every day.
