3 point for super M
fred
10-21-2003 19:19:39
I have a super M without a 3 point. I need something to move round bales to feed the cows. Would my super M (tricycle) do the job if I put a 3 point on it.. Would it be worth it?
Mickey Cook
10-22-2003 03:55:04
 Re: 3 point for super M in reply to fred, 10-21-2003 19:19:39
I have an M with a three point hitch on it. I might be willing to sell it if your interested.
Dan
10-21-2003 19:22:41
I think the 3 point is definitely worth having on the super M. As far as moving round bales, you may need weight on the front to hold it down. Believe most 3 points, especially like Saginaw with the 2 cylinders will lift them fine but the tricycle tends to be light on the front
David Nemeth
10-25-2003 18:49:30
 Re: Re: 3 point for super M in reply to Dan, 10-21-2003 19:22:41
The 3 point hitch is a great addition to a Super M. I have had one on my 53 for many years. Have used it to pull a JD 3 bottom mounted plow (16 inch), cultivator, scraper blade, and in winter a 7 foot Erskine snow blower. When I use the snow blower I bolt 2 rear wheel weights to frame rails. This along with the wide front keep the front end on the ground where it belongs.
