M piston size and turbo
collegeboy
10-21-2003 19:52:41
Well I am sitting up at school think about the old farmall M. Having grown up arounds these and worked on many of them. What is the absolute largest piston that could be put in the block with and still use a sleeve. And has anyone ever thought of putting a small turbo on one. Thanks fellas
little red turbo puller
01-28-2008 10:28:38
 Re: M piston size and turbo in reply to collegeboy, 10-21-2003 19:52:41
I have a 1941 farmall H with a turbo on it. It is a stock motor. It is making about 80 pto Hp at 15 psi.There are some tricks to get it to work with a up draft carb.
max adams
10-22-2003 16:53:54
i'm not sure as far as pistons go.but with the muscle cars that i've messed with,you can do anything i've seen some wild set-ups.so i guess
one could do the same with the M.gas is gas and always remember(theres no replacement for displacement)...a little joke! as far as the turbo,on a gas engine i always thought you had to have a waste gate? and these can be a pain!
again anything is possible.this is my two cents!
bindernut
10-22-2003 10:04:32
Seen an M with 4 1/8 pistons(stock 450 pistons) Block had to be bored slightly to accept sleeves that big. This is what I've been considering doing on my M.
Bindernut
rustyfarmall
10-22-2003 12:52:39
 Re: Re: M piston size and turbo in reply to bindernut, 10-22-2003 10:04:32
I saw one like that too, they had to stop using the tractor when the thin cylinder walls cracked.
Dr.EVIL
10-22-2003 07:33:01
Son & I (Son's also a college Kid) have had this discussion many times. Firing order in the H & M are O-K for naturally asperated engines but not the best for forced induction. First thing You have to do is change the cam so You can alter the firing order. Stock is 1-3-4-2, and you need 1-4-2-3 or 1-3-2-4. Problem is the front two & back two cylinders share intake ports. Once You fix the firing order You can adapt a Ford Mustang A9L computer from a 5.0L HO Mustang to run electronic fuel injection. Then You can just absolutley go crazy with boost & add-on boost control parts.
Troy - MI
10-23-2003 14:29:45
 Re: Re: M piston size and turbo in reply to Dr.EVIL, 10-22-2003 07:33:01
In order to change the firing order, you'd have to change the crankshaft too. For instance, if your order changed to 1-4-2-3, piston 1 and 2 would have to be in the same position in the sleeves. Same with 3 and 4. OEM engines have pistons 1 with 4 and 2 with 3. How do you accomplish this? Do you mill a new crankshaft? Sounds like a lot of work!
Dr.EVIL
10-25-2003 05:09:04
 Re: Re: Re: M piston size and turbo in reply to Troy - MI, 10-23-2003 14:29:45
The M's & H's have 180 degree crankshafts, two pistons up and two down. The crankshaft shouldn't need to be changed. Timing events are controlled by the cam, so from 1-3-4-2 I guess the new correct timing order would be 1-3-2-4, or 1-4-2-3. I don't know what that would do to harmonics in the crankshaft. Ignition firing order could be changed at the distributor cap. Goal is to get the intake drawing air as smoothly as possible, and to convert to electronic fuel injection. With the right tuning software the 49-state manual transmission '87-'93 Mustang computer A9L has all the other parameters including cylinder count adjustable with a computer.
Troy - MI
10-25-2003 17:31:39
 Re: Re: Re: Re: M piston size and turbo in reply to Dr.EVIL, 10-25-2003 05:09:04
Think about it. The position of the pistons match the firing order. Each piston in the order are 180 degrees from each other. 1 is 180 from 3 is 180 from 4 is 180 from 2. Changing the camshaft order to 1-4-2-3 would mean that piston 4 would be 180 degrees 'out of phase' WRT the cam. Same story for piston 2. The distributor timing could be changed to match cam timing by switching plug wire locations. But pistons 4 and 2 would be at the bottom of their cylinders when their plugs fire. If only the camshaft/plug wire timing were changed, you could get away with getting the engine to rotate in the opposite direction. This is how twin/four engine piston-powered aircraft engines are designed.
My first passion is building '60s Pontiac GTOs....I've tried so pretty strange stuff to get more HP. But forging and milling a new crankshaft is beyond my abilities.
Troy - P.E.
sod
10-22-2003 22:37:22
Why do we have to change the firing order? I'm not trying to be a smartalec, I just need to know.
good luck
sod
Dr.EVIL
10-23-2003 07:35:45
 Re: Re: Re: M piston size and turbo in reply to sod, 10-22-2003 22:37:22
The intake ports are siamesed, meaning they split into two ports inside the head. This is O-K for a naturally asperated engine since the first cylinder starts the air/gas mixture moving into the first cylinder and when the intake valve closes the mixture is already moving and just diverts towards the other cylinder with the open intake valve. Under boost You exaggerate this situation and would have one cylinder getting more mixture than the other, making more power and making tuning a bear! It "MAY WORK" with the OEM firing order, but it would probably work better with it changed. In order to make the turbo fit I'm assuming your throwing the entire intake/exhaust manifold out and fabricating from scratch. I saw a 1939 to 1942 gasoline powered FARMALL M at a Super Stock tractor pull 30 yrs ago in Davenport, IA that was turbo-charged but I never saw the left side of the engine to see how He had it plumbed. He was still running the IHC Magneto. He also had PLENTY of power for the class He was pulling in! I also have a small picture with caption from a farm magazine from 25+ yrs ago about a Farmall H that was turbocharged. Gas engines really don't lend themselves to turbocharging. The pressurized fuel/air charge burns WAY too hot. And most people try to run way too much static compression. A good turbocharged gas engine needs to have 6 or 7 to 1 compression, REAL good gas, Best ignition possible, and then should be able to make 2, maybe 2-1/2 HP per cid. The trick is to run low compression with LOTS of boost. Even diesel engines run this way now.
rustyfarmall
10-22-2003 04:56:44
On a straight M, 4 inch is the max. Super Ms can go 4 1/4.
Someone posted a picture quite a while back of an M diesel with a turbo, I don't know why you couldn't put one a gas, it would take some engineering, but nothing is impossible.
Nebraska Cowman
10-22-2003 04:10:50
I had a super M with 4 ¼ inch pistons. Am sure there were tubo kits too.
