FARMALL A MAGNETO
Gene C.
10-22-2003 04:00:09
The H magneto on my Farmall A went bad. The repair shop suggest replacing it with an available Wico magneto. Was the Wico an option on the Farmall A or an aftermarket replacement?
Nebraska Cowman
10-22-2003 04:14:33
 Re: FARMALL A MAGNETO in reply to Gene C., 10-22-2003 04:00:09
the wico is aftermarket. good modern mag if you are not concerned with orinality. The IHC is an exelent mag too and still easy to find parts for. give this a little thought before you start writing the check.
mag
10-22-2003 15:18:05
 Re: Re: FARMALL A MAGNETO in reply to Nebraska Cowman, 10-22-2003 04:14:33
If your mag does not produce any spark, a cheap fix is to buy a 10-15.00 6volt coil from napa and add the coil , and then use the mag as a distributor. I just bought an (h) that someone had set up like this.
