300 Utility Clutch, Torque Amplifier, PTO
Mike J.
10-22-2003 10:48:13
My 300 is getting a much needed overhaul. I have never replaced a clutch, or done any work to the T/A, so I am a little uneasy at starting this task. I assume the clutch needs replacing due to little or no adjustment can be made. The longer the tractor runs, the harder it is to shift without grinding a gear. Also, my T/A has never worked. I can not tell a difference when the T/A lever is moved to one position to the other. Lastly, my rear PTO works, but when I shut it off during operation, I hear a whinning sound. Since many of the readers of this forum are experts at tractor repairs, can you give me some advice? Are all three of these problems related?
Thanks for your time and advice!
Red Rider
10-22-2003 20:46:32
 Re: 300 Utility Clutch, Torque Amplifier, PTO in reply to Mike J., 10-22-2003 10:48:13
I have two IH 300 tractors. A Utility and Farmal that I have gone through from one to the other on both. If you have adjusted the clutch pedel so you can feel it touch the throw out bearing with the pedel about 1 and 1/4 in from the platform and it still is not releasing then I would say you will have to replace it. It is not that hard to replace the clutch componants once you get the tractor split. Once you get to the clutch you should inspect the starter ring gear, have the flywheel turned, replace the pressure plate, clutch disc and install a new throwout bearing. Now you could probably get by without replacing the pressure plate but the way I look at it, once I get the tractor split I want to replace everything so I don't have to split the thing again. Now for the TA. If you say nothing happens when you change the positions of the TA lever then something is not hooked up or adjusted correctly. You see if you TA is out and you pull the TA lever back your tractor will stop. A weak TA will move on the low side but will slip badly with the lightest load. As long as you have to split your tractor I would also split the TA section and have it rebuilt or rebuild it with a sprague lock up and eliminate the ramp and roller factory set up. The PTO will make a slight whinning noise when in the locked off position. I generally just leave mine engaged unless I have PTO equipment hooked to it. You see there are more gears turning unengaged that engaged. Hope this helps. If you don't have the parts, owners and operators manuels you should get them. They will walk you through any repair job you will encounter with your 300. Good Luck
Chadster
09-05-2004 13:20:24
 Re: Re: 300 Utility Clutch, Torque Amplifier, PTO in reply to Red Rider, 10-22-2003 20:46:32
We just bought a 300 UT and started mowing with it, stopped for a minute and then was going to start again and now we can not get it to move. I believe it is the clutch that is out. We can go through all the gears whether the engine is going or not. Looking through the inspection opening under the clutch assembly I can see that the clutch pedal is moving the release bearing is engaging and disengaging the pressure plate but still no movement. We are very new to this and no manual just yet. Didn"t think we would need one this quick. I understand what a TA is but where is the lever located? Any information would be appreciated..
SCOTT
10-24-2003 23:50:14
HEY IF YOU DECIDE TO FIX YOUR TRACTOR,GET BACK WITH ME AND I SHOULD BE ABLE TO SAVE YOU SOME MONEY.I'M IN TEXAS BUT I TAKE PARTS DOWN TO & BACK FROM MEXICO WHERE THE PARTS ARE LESS EXPENSIVE.(JUST LIKE MEDICINE)THESE PARTS I HAVE IN STOCK AND I CAN ALSO HOOK YOU UP WITH A SERVICE TECH IF YOU RUN INTO PROBLEMS INSTALLING.THANKS
Mike J.
10-27-2003 10:13:08
 Re: Re: Re: 300 Utility Clutch, Torque Amplifier, in reply to SCOTT, 10-24-2003 23:50:14
Scott, please send me your email address. My email address is johnsonm@opexonline.com. Thanks.
john Reed
10-26-2003 20:02:18
Scott if you read this --pse email me : skinner@uci.net I need some pto parts.
