300 utility doesn' t steer well with one wheel
Duane Fleming
10-22-2003 14:48:32
I have one front wheel in my truck wish it was somewhere else. The steering knuckle broke off just before it enters the main upright beam. Would a weld job be strong enough.I doubt it but that is not my speciality. Any good tips on where to locate a part store or used supplier. I heard from you guys the weak point of the 300u was the steering. Is this one of the weak points and should I investigate other components?
TDK
10-23-2003 13:16:10
 Re: 300 utility doesn' t steer well with one whee in reply to Duane Fleming, 10-22-2003 14:48:32
Have some 300U parts tractors.May have what you need.E-mail me with more info and part #, I'll see what we have.
dick
10-23-2003 09:02:12
Steering is definitely a major engineering weaknesses of the 300U, but it usually shows up in the spindles or gearbox - it's likely you'll be able to find a replacement for your broken knuckle fairly easily (I think). I wouldn't try welding your broken piece - liable to go bust on you at the worst possible time and put you in the ditch, or worse.
I've had pretty good luck with getting salvage parts from J.P. Tractor Salvage, 573/783-7055. Not particularly cheap, but they generally have what's needed in pretty good condition. There are a lot of other salvage dealers around if JP doesn't have it, repost for a list if necessary. Good luck!
R. Marg
10-22-2003 15:09:24
e-mail me for a phone # for a place that should be able to help
