F-20 Flywheel
I RIGHT I
10-22-2003 18:42:44
How does the flywheel come off of a F-20?I've got the motor(Tractors have motors,cars have engines)setting on a work bench and can,t see how to get the flywheel off.I know I should get a manual,but I am just fixing leaks and cleaning it up to repaint. Thanks IRI.
Nebraska Cowman
10-23-2003 04:31:03
 Re: F-20 Flywheel in reply to I RIGHT I, 10-22-2003 18:42:44
there are tapped holes in the fywheel to attach the puller.
I RIGHT I
10-23-2003 05:16:09
 Re: Re: F-20 Flywheel in reply to Nebraska Cowman, 10-23-2003 04:31:03
There is also a small alignment bushing that has internal threads,does this come out with the flywheel or does it need to come out first?
F-Dean
10-23-2003 06:26:02
 Re: Re: Re: F-20 Flywheel in reply to I RIGHT I, 10-23-2003 05:16:09
The flywheel will come of easier with this pin removed but they will come off together.
F-Dean
10-22-2003 19:01:24
Take the big nut off and pull! A big gear/pulley puller works fine.
R. Marg
10-22-2003 18:54:19
well cars/truck/and tractors have engines motors are eletical engines use fuel of some sort and have combustion
Nebraska Cowman
10-23-2003 10:52:26
 Re: Re: F-20 Flywheel in reply to R. Marg, 10-22-2003 18:54:19
it's just how we talk R marg. And car engines get "frozen" Tractors are just "stuck", a tempoary problem.
