Do you use your M's PTO
David
10-23-2003 07:26:44
I am having a lot of trouble with my M's PTO. It slips when under a heavy load. What can I do? Mine is the earily type with the flat plate on the outside. Is the later one any more dependible? Does the later one also use the two probes that mesh with the tranmission shaft or is it splined on both the PTO and transmission shaft?
Are the two interchangible?
Do any of you use your PTO?
Roger
10-23-2003 20:06:53
 Re: Do you use your M's PTO in reply to David, 10-23-2003 07:26:44
David, I use mine on the sheller for about 4300 bushels a year & have also used it on the auger when emptying the bin (10,000 bushels). Never had a problem yet..Roger
Allan
10-23-2003 17:31:13
David,
Are you hooked to a slip clutch?....I can't in my mind see how it could "slip".
Seems to me that it would either pull or it wouldn't pull.
Allan
David
10-23-2003 19:19:36
 Re: Re: Do you use your M's PTO in reply to Allan, 10-23-2003 17:31:13
Maybe slip is the wrong word. It disengages and engages. Sounds like gears slipping. When I pulled it out the notches were rounded and it was obvious what was happening.
My question is should I go back with the same style or change to the spline style.
Thanks
Will Sick
10-23-2003 22:25:11
 Re: Re: Re: Do you use your M's PTO in reply to David, 10-23-2003 19:19:36
If just the pto is rounded you might get by with replacing that.There is also a snap ring that keeps the counter shaft from moving forward. That could have come out. You would be better off with the spline set up if you want to really use it quite hard.
49 Cubber!
10-23-2003 15:56:02
You sya its slipping,are you sure its not the clutch slipping intead.What are you doing when its slipping,anything in particualr.I have 2 41 Ms and each has a differnet type of pto on it.One may have been changed at some point to the later style.
Michael Soldan
10-23-2003 15:51:57
David, I use the PTO on my M to run hay elevator, sometimes a manure spreader and have never had a problem.The M is a 1940..... ....Mike in Exeter Ontario
Will Sick
10-23-2003 10:26:07
The newer pto's are splined. The old notch in does not inter change with the splined set up. In order to go to the newer one you have to chang the counter shaft in the transmission. That is a major job. Yes, I use the pto on my M to run a sickle mower with no problems.It is a 1950 with splined pto.
David Nemeth
10-25-2003 18:37:12
 Re: Re: Do you use your M's PTO in reply to Will Sick, 10-23-2003 10:26:07
I farm with 2 M's, a Super M, and a Super W-6. My one M is a1940 with the old style PTO and does the same thing yours does. The other tractors have the splined PTO and they are always doing all kinds of heavy PTO work with no problems at all. The later style PTO was much better!
