I.H. trailer mower
rustyfarmall
10-23-2003 11:44:56
I was at an auction a while back and picked up an IH trailer type hay mower, It is pretty rough, been sitting outside for many years, but I think I can turn it back into a mower again. Question is, where is the model number located? The mower is PTO driven, belt drive, with a pitman stick. I need to know what model this is so I can start hunting for parts.
ihkovas
10-23-2003 12:36:23
 Re: I.H. trailer mower in reply to rustyfarmall, 10-23-2003 11:44:56
My guess would be a model 32. This pull type was built from 1956 and was the first pull type built for tractors. The wheels are slightly off-set and the rest of it resemble the model 31. If you can get some part numbers off of it,I'll look them up in the parts book I have.
TomH
10-23-2003 16:30:46
 Re: Re: I.H. trailer mower in reply to ihkovas, 10-23-2003 12:36:23
If it has rubber tires its probably a 32, I believe earlier models all had steel wheels.
rustyfarmall
10-23-2003 16:10:44
Here are some part numbers I found on the mower.
drive pulley-112570
driven pulley-451473R1
castiron part that bar attaches to 45149LR
ihkovas
10-24-2003 00:55:38
 Re: Re: Re: I.H. trailer mower in reply to rustyfarmall, 10-23-2003 16:10:44
Rustyfarmall---the 451473R1 and the 451491R1 was used on both the 32 pulltype and the HM24 mowers.
I couldn't find the 112570 number in this parts book,thats dated 5-16-55
rustyfarmall
10-24-2003 04:23:57
 Re: Re: Re: Re: I.H. trailer mower in reply to ihkovas, 10-24-2003 00:55:38
Thank you, to both of you, at least now I have an idea.
