Flail Mower for Farmall H
Frank Z
10-23-2003 12:51:01
I want to pull a flail mower with a Farmall H (equipped with a 3pt.) My son says I need a mower wider than the rear tires but I have read on this site that the flails lift the grass after the tires have pressed it down. Also does the H have enough power to pull a flail mower wider than 6 feet.
Dr.EVIL
10-23-2003 12:55:58
 Re: Flail Mower for Farmall H in reply to Frank Z, 10-23-2003 12:51:01
Depending on what Your trying to mow..... NO. Dad tried to mow His CRP setaside with a flail mower and He ended up buying a Super M to pull a 6 ft. mower. He was trying to run in 3rd gear, about 5 MPH. Your H would only run about 4 MPH in 3rd., but still would be too fast for the horsepower available. Dad was trying to mow heavy thick cover crops 2 ft tall You could barely walk through. A rotary bushhog pulls just a bit easier, and sicklebar mowers pull real easy.
