766 gas
Brandon
10-23-2003 18:38:54
I am looking at a 766 gas with a factory cab. Appears to be in good condition, just a glance from the road though. Are these good tractors? What HP? Did they have a 3 or 4 speed transmission? If it is in decent mechanical condition with good tires what is a ballpark price for it? Any other comments are apreciated, thanks. Brandon
ny bill o
10-25-2003 18:37:31
 Re: 766 gas in reply to Brandon, 10-23-2003 18:38:54
if being a gas would be a problem depends what you are using it for. should start easier in the winter. if you can buy it cheap enough compared to a diesel, you can afford to put some gas through it. i'd think the cab would be more of a deterrent to buying than the gas. you can't see as well out of them as an aftermarket cab of the same era. i have a 966 that has been a good tractor, though not nimble. i would think the 766 would handle more like my 826, which is quite maneuverable. as to price, a 766 diesel would bring $5-7000 from a dealer, usually less in a private sale. the gas should be $1000-1500 less. having said that, watch it sell for more.
the tractor vet
10-23-2003 19:45:59
They were ok a littel light on pony power for the weight of the tractor , a freind of mine has one that he bought junk and i went from the ft to back and had ever bolt nut and screw out of it to make a good one but when we were plowen together my 706 gaser would walk away from him but on the dyno he had me by 9 hp but i weighed 1500 less then he did.
Farmer John
10-23-2003 22:20:11
 Re: Re: 766 gas in reply to the tractor vet , 10-23-2003 19:45:59
I had one a few years back. I think around 80 hp. Gas Guzzling is an understatement. 4 speed trans with hi/lo. Good tractor but loved gas..
Brandon
10-24-2003 05:13:09
 Re: Re: Re: 766 gas in reply to Farmer John, 10-23-2003 22:20:11
About how many gallons per hour will this tractor use doing heavy tillage?? (Worst case scenario) How about cutting and baling hay? Hopefully gas consumption would be less.
Bill
10-24-2003 17:27:45
 Re: Re: Re: Re: 766 gas in reply to Brandon, 10-24-2003 05:13:09
A neighbor had one a few years back. Pulling a four bottom plow used about 8 gallons a hour. Might use a little less on hay. I think you'll be better off with a diesel unless you can get it super cheap. Good luck with it if you decide to buy.
