560 generator question
Farmall Daddy
10-24-2003 13:47:41
I bought me my first 560 here about 2 months ago. The generator was charging good until about a week ago. I took it to a tractor pull, and I looked at the gauge, and it didn't read anything. I shut it off, and a while later, fired it up, and it was charging. Shut it down when I was done pulling and it didn't read the next time I had it running. The gauge hasn't moved since then. Any ideas? Thanks for the help!
steve
10-24-2003 17:57:28
 Re: 560 generator question in reply to Farmall Daddy, 10-24-2003 13:47:41
--ground the "F" terminal of the generator to the tractor frame instead of going thru the regulator. if that works , part of the reg is the problme.
--if not, short the B and A terminals on the regulator together to test the other two coils. if the amp meter now works, the toerh part of the reg is bad.
--if F is grounded, B and A terminals are jumpered, and you have no output, then generator is bad.
R. Marg
10-24-2003 13:56:30
it could be the points in the regulator are caroded or the brushes in the genarator are getting worn out
