12 volt starter?
farmallsc
10-24-2003 18:40:36
my super C is a twelve volt system. and i cant find a twelve volt starter do they make a 12 volt starter or how does it work?
Les...Hey farmallsc
10-24-2003 19:17:14
 Re: 12 volt starter? in reply to farmallsc, 10-24-2003 18:40:36
In case you didn't see my post down below, are you in NH? If so, where?
BTW, I agree with the others on the starter business.
farmallsc
10-25-2003 08:26:40
 Re: Re: 12 volt starter? in reply to Les...Hey farmallsc, 10-24-2003 19:17:14
well im down in hopkinton just south of concord, if you know the area im not the one with the hey feild im at the old sunset farm although i dont live there my grandma does and her barn is my super C's home
Bill B
10-24-2003 19:01:38
The 6 volt starter will work ok, but may eventually break the starter drive, since it slams in gear much harder with 12 volts. If you want, you can have an auto electric place rewire the field coils. I cant remember for sure, but I think the coils are wired in series for 6 volts and paralell for 12. I would not worry too much about it. I have 12 volts on my cub and it works fine.
Hugh MacKay
10-24-2003 19:34:55
 Re: Re: 12 volt starter? in reply to Bill B, 10-24-2003 19:01:38
Bill: On that starter drive, there are two different drives; the old bendix type and a newer clutch type. This newer clutch type takes that slam out of the starter hitting hard. Much easier on starter and ring gear. The only place I have ever seen the newer type is at CaseIH dealers. I have it on all my tractors even the 6 volt one. The difference is unbelievable.
CNKS
10-24-2003 18:45:06
You don't need one -- I have drained a 12 volt battery several times with a 6 volt starter, and never hurt the starter. But, if you insist it can probably be rewired.
bindernut
10-26-2003 09:24:57
 Re: Re: 12 volt starter? in reply to CNKS, 10-24-2003 18:45:06
When my cousin swapped his H rom 6 to 12 volts the guy at the dealer told him to not worry about the starter till it broke. That was years ago, and he's never done anything with it. works fine.
