Farmall 450 2 piont hitch
R. Marg
10-25-2003 08:13:27
well guys on my 450 there are some parts on the left side of the hitch that don't seem to be hooked up and or are missing some parts one is a handle that comes up under/by the seat it has catches it looks like it could be a hitch lock but the low end of it just hangs there not hooked up to any thing abody able to tell me what ect this does and what would be real great would be a picture of this area of a 450 so I could see how it should be Thanks for any help you can give me
Farmall450man
10-27-2003 06:04:48
 Re: Farmall 450 2 piont hitch in reply to R. Marg, 10-25-2003 08:13:27
R. Marg, The is an IH publication for the FH for the 450's & 350's. It shows the parts and the proper set-up for different implements and pulling conditions. Sometimes this publication shows up on eBay. If you cant't find one, e-mail me. If the FH isn't set-up correctly for what you are pulling, you won't see a benefit. When it is working correctly, it will increase the loading on the rear tires. My 450 had some parts that had been lost and replaced with cutting-torch made parts. I was able to get used parts from Bates. I believe that JP Tractor Salvage would also be a good source. I have always benn pleased with JP.
ihkovas
10-25-2003 20:56:09
third party image
If I did this right,here is a picture of mine on a skid
ihkovas
10-25-2003 20:57:40
 Re: Re: Farmall 450 2 piont hitch in reply to ihkovas, 10-25-2003 20:56:09
Well, it's in the parts and pieces
RAW in IA
10-25-2003 19:11:11
Like Geoff said it is a draft control lever. Dad had a 350 and we had a 3-16 monted plow. we kept the draftcontrol locked down because it never worked for us. It is not an essential piece of equipment in orderto use the fast hitch.
Geoff
10-25-2003 15:20:11
It's a draft control, different settings give a slightly different pulling angle from the front of the 2pt hitch. IH also had a setup with a hydraulic cylinder to accomplish the same thing. Try playing with it while using 2pt equipmmment such as a plow.
