Fuel tank gasket leak, help
Gramps544
10-25-2003 12:15:47
I have a I-544 and where the fuel sender connects to the gas tank (top) it is leaking at the screws. I have replaced the gasket with no noticabe change in the leak. Usually this area is covered by the console cover, so it could have been leaking for some time.
Does anyone have any tricks for sealing gaskets from fuel? I would think most sealers would desolve in time from the exposure to gas.
Nebraska Cowman
10-25-2003 19:02:43
 Re: Fuel tank gasket leak, help in reply to Gramps544, 10-25-2003 12:15:47
I bet it is leaking around the screw threads. try using a little gasket shellac on the threads.
Gramps544
10-27-2003 13:53:31
 Re: Re: Fuel tank gasket leak, help in reply to Nebraska Cowman, 10-25-2003 19:02:43
That is exaclty were it is leaking. What is gasket shellac? I will go to NAPA and see if they have some. Thanks
