400 wrist pin-bushing-piston assembly
Ohio Bill
10-25-2003 13:25:44
I am rebuilding a 400. Have begun trying to assemble the new parts and am experiencing difficulty getting the wrist pins to go into the pin bushings. Are these supposed to fit easily or do they require a press? Thanks
Aces
10-25-2003 16:18:06
 Re: 400 wrist pin-bushing-piston assembly in reply to Ohio Bill, 10-25-2003 13:25:44
The bushings need to be honed or bored, boring is best that way bore is square with rod bearing.
justin
10-25-2003 14:19:33
They should actually be sized to the pins. take them to a local machine shop to have this done. it will probably cost $5-10/rod..
