Order Farmall Cub Parts Online
Cub Engine (question too tough??)
Kevin (FL)
10-27-2003 06:00:50
I posted this question the other day--it's already on page 2 and no one answered. Maybe it's a dumb question?? Here's the post over--sorry for the re-run:
I'm about to build a Cub engine from some salvaged parts. I just heard that the C60 blocks (early/later) used different pistons. I haven't read about this in any of my reference books. Can anyone shed some light on this? I'm assuming that the wrist pin-to-crown distance must be a little different. Don't want to bang pistons into the head or anything or have too low compression if the pistons are too "short".
Thanks for any help.
Phlogiston
10-27-2003 10:28:53
 Re: Cub Engine (question too tough??) in reply to Kevin (FL), 10-27-2003 06:00:50
No, not enough room for .090 over. .040 is pushing it.
JD
10-27-2003 09:27:04
A few years ago I bought oversize aluminum Cub pistons from Case/IH. Can't remember if they were 60 or 90.
JD
George Willer
10-27-2003 06:17:20
There are a number of differences in pistons, heads, crankshaft bearing mounting, manifold, etc. Do you have a parts manual?
George Willer
Kevin (FL)
10-27-2003 07:05:07
 Re: Re: Cub Engine (question too tough??) in reply to George Willer, 10-27-2003 06:17:20
Have operator & service manuals--no parts manual. Looks like I need to get one??
George Willer
10-27-2003 08:58:23
 Re: Re: Re: Cub Engine (question too tough??) in reply to Kevin (FL), 10-27-2003 07:05:07
You're flying blind without one.
George Willer
Buzzman72
10-27-2003 06:13:13
Kevin, I've never heard of pistons with diffferent compression heights being used in a C-60...but I don't have my TC-37 Cub parts book handy, so at the moment I can't give you a definite answer. But maybe someone else can.
(At one time, the old M&W Gear Co. made pistons fro a Cub in .090 oversize...in combination with a power unit governor [2200 rpm vs. 1800 in the tractor version] and some judicious carb jet drilling, you might build a bear of a Cub, if you can find some of these older parts.)
Kevin (FL)
10-27-2003 07:09:34
 Re: Re: Cub Engine (question too tough??) in reply to Buzzman72, 10-27-2003 06:13:13
Thanks Buzzman,
I haven't measured the bores yet to see what size pistons I'll need, but the block I have doesn't have a ridge in the bores--was hoping it was standard bore. Is there enough material in the casting to go .090" on the overbore? I get nervous when I go .060" on my truck engines.
Buzzman72
10-28-2003 07:01:32
 Re: Re: Re: Cub Engine (question too tough??) in reply to Kevin (FL), 10-27-2003 07:09:34
Evidently there was enough material to go .090 on THAT particular one...it's still running, BTW, after about 40 years on the rebuild...
