H engine bearings
Bill
10-27-2003 06:18:21
I found bearing flecks in the oil and had low oil pressure. After dropping the pan I found rod bearings with bearing material flecking off. The bearings are international made by Clevite. My question is what are opinions on brand of bearing, Clevite or other brand? I don't remember having this problem with other engines. Date on the bearings is 2-89.
Thank you, Bill
justin
10-27-2003 14:35:06
 Re: H engine bearings in reply to Bill, 10-27-2003 06:18:21
Clevite bearings are a top of the line bearing (CL77). IH had their bearings made mainly by Federal Mogul, and some by Clevite. The Clevite CL77 class bearings are heavily used in high performance engines, i.e. NASCAR & other motorsports. What you are probably facing is an out of dimension crankshaft, Bad Oil Pump, or at one point in time water was in the crankcase and deteriorated the bearing materials.
Jim J
10-27-2003 13:50:09
Check your oil pump
R. Marg
10-27-2003 07:51:04
hows the crank shaft if its out of round if will do that to the bearings
