Rebuilders of 450 pump/valves?
Rusty Stuff
10-27-2003 16:58:55
Any advice on rebuilding pump and valves? Can you still get parts? Slow as molasses, bucket drops aways if you run the tilt valve, seems to lose oil, but not much leakage visible. Is there a source of rebuilt assemblies? Can the pump be "souped up" from original? RS
Ohio Bill
10-28-2003 04:41:36
 Re: Rebuilders of 450 pump/valves? in reply to Rusty Stuff, 10-27-2003 16:58:55
Just finished rebuilding all three hyd valves and the regulator valve on my 400. There are many small parts in these things but I had an IT book with a parts illustration as a guide. I was able to find all of the various o-rings, gaskets and repair parts at the IH dealer. Spent about 40 bucks. Have not messed with the pump though. You might pull the strainer from the right side of the hyd tank to see if it's plugged.
