rocker arm assembly
Buster here aga
10-28-2003 11:09:28
I had to take the rocker arm assembly off the head on my Farmall 100 due to a hard to get at head bolt. Will the rocker go back on like it is or will I have to do something with the valve springs? Thanks for the help you all have given me before. Buster
Buster
10-29-2003 06:14:25
 Re: rocker arm assembly in reply to Buster here again..., 10-28-2003 11:09:28
Thanks for the help.Do i check the valve lash by taking the plug out of each cylinder and let it reach the top then check the valve clearance or how do i do it?
Haas
10-29-2003 05:56:50
There is a notch in the rocker shaft that accomdates the stud bolts that hold the assembly in place. Make sure that is lined up when you put it back. Others are correct on adjustments, etc. I had a Farmall C that the notch in the rocker shaft was not lined up when someone put the rocker assembly on. They forced it on anyway. I had a real hard time getting that off!! So it the assembly does not go freely down on the stud bolts, something is not right.
rustyfarmall
10-28-2003 14:00:11
If you have removed the head, you will need to adjust the valve lash, even if you hadn't touched the rocker arm.
Gary_N_WV
10-28-2003 12:07:57
Buster,
When you to put your rocker assembly back on, just line everything up making sure the little ball end fits down in the push rod and that your push rod is seated in the lifter as you tighten the rocker down.....the other end that fits on the valve end will push the valves down (assuming they are in an open position etc.)
You probably will need to check the valve lash to make sure it's still at the right setting when hot.
