Help!! Splitting the 350 Farmall
Greasy John (Or
10-29-2003 07:27:04
Any of you Farmall Mechs tell me what keeps my 350 from coming apart at the front of the transmission ---I removed all the bolts and she opened up abt 1/8" Then stopped. Do I have to go into the back to the tranny to disconnect the main shaft or what. I ordered a manual but all I got was the engine section.I have to split it to replace the driven PTO gear and front shaft. Any help will be appreciated John
scotc
10-31-2003 18:47:11
 Re: Help!! Splitting the 350 Farmall in reply to Greasy John (Or), 10-29-2003 07:27:04
could be the pilot bearing stuck- had a heckova time with the 756 because of it, about 1/8 to 1/4 inch apart. were lifting the front section with the backhoe to pull it out and block it up, pulled a little with it and used pry bars to get it apart.
Greasy John
11-01-2003 18:06:33
 Re: Re: Help!! Splitting the 350 Farmall in reply to scotc, 10-31-2003 18:47:11
Thank you scotc --Well i finally got it apart today.Just wasnt getting tough enuff with it I gess.Built up an I beam jig under the tractor blocked the back on it and used a come-along and chisels and bars and she finally came in 2 peices. Tnx to all who tried to help and special tnx to Pete at Wisconsin tractor who sent me the 8 pages if dope on the 350 and several other with the T/A unit Oh yes I built a jig on rollers to hold up the front half and I can roll her back and forth by hand now. Whatever works RIGHT!!! Tnx again all. John In Oregon.
scotc
11-07-2003 21:07:47
 Re: Re: Re: Help!! Splitting the 350 Farmall in reply to Greasy John, 11-01-2003 18:06:33
whatever works is right- having backhoes and skidsteers around makes splitting tractors a lot easier. another trick we have is when my uncle bought his 300 and had to split it, he welded feet onto the end of some old spreader web crossbars and cut holes in them to bolt onto the sides of the bellhousing to use as legs. Works on the little ones but anything biger than the 400 gets blocking stacked under it
Check this bolt
10-29-2003 08:27:32
Drop the cover from the rear belley of the T/A housing. There is 1 bolt in there you have to remove.
Greasy John
10-29-2003 10:32:04
 Re: Re: Help!! Splitting the 350 Farmall in reply to Check this bolt, 10-29-2003 08:27:32
Try it again! Yes I have the one bolt inside the case out. The PTO splined shaft I think is free but something else has to be holding the main shaft of the tranny from coming out of the T/A case. Which makes me think I have to disconnect something in the tranny or in the clutch-T/A unit. ???? Tnx for the comments!
Another thought
10-29-2003 11:11:15
 Re: Re: Re: Help!! Splitting the 350 Farmall in reply to Greasy John , 10-29-2003 10:32:04
You may have play with the gear position on the TA/mainshaft gear. There is a bearing cage that fits on the input shaft of the tranny that goes into the backside of the TA- sometimes it gets hung up. But things should come apart smoothly.
26Red
10-29-2003 08:21:45
You may have one or 2 bolts left on the top side that screw into the block from the starter area. One is in plain view, the other you will remove the starter and just above the ring gear for the bolt...
26Red
10-29-2003 08:23:25
 Re: Re: Help!! Splitting the 350 Farmall in reply to 26Red, 10-29-2003 08:21:45
Guess I should read your whole post before answering. Sorry..
