What size IH loader for International 240
Jerry Deubner
10-29-2003 19:33:57
What size IH loader would be good for a 240 IH Utility? Also, would a Super C fasthitch fit the 240?
Thanks,
Jerry
Stan(VA).
10-30-2003 05:09:39
 Re: What size IH loader for International 240 in reply to Jerry Deubner, 10-29-2003 19:33:57
IH loaders of that period would be the 1701 or 2001 series, but be aware that you don't just look for a 2001 loader. They are all called by the same series but you ordered the frame specific to your tractor. The 2001 was available for everything and came with a different set of front brackets and a different weldment (and different length) on the lower frame that attached to the rear axle housings. So you can find a 2001 on a 240 or 404 and on a 656, but they won't interchange without help from your welder ;) No, the Super C fasthitch will interchange with a 200, the 230 and 240 I belive will interchange, but since you are working with a utility I would guess that there are some unique parts on the utility models to alter the working range of the hitch compared to a row crop 240.
Stan(VA).
