Starter motor switch problems
Kurow
10-30-2003 01:41:12
I have a Farmall AV and with it is a Delco start model 1070999. This is not in any of the AV or Super AV parts books. It has a solenoid on top so requires a starting switch of some description as opposed to pull rod. I have seperate ammeter/ligting control box.
So.. What is the right starting switch and where should it go? I am tempted to drill a hole into the control box and stick in there? Thanks for your help. Photos appreciated.
gene b
10-30-2003 02:17:08
 Re: Starter motor switch problems in reply to Kurow, 10-30-2003 01:41:12
If you want it to be original you can change the stud to the type for the original type button. Second where are the drilled holes for the original switch. Tthe button should be on the BENDIX end along with the two holes drilled and tapped for the switch. Must have a starter for an H or M on there now. You can get the correct starter from a rebuilder at around 100 exchange.
