What fluid for power steering 400 rc
Kelly C
10-30-2003 06:17:51
My 400 has factory ( I was told) power steering.
Needs some fluid but not sure what to put in there.
I have loads of hytran around will that work?
TP from Central PA
10-30-2003 12:10:23
 Re: What fluid for power steering 400 rc in reply to Kelly C, 10-30-2003 06:17:51
If it is "Factory" it gets its oil from the hydraulic system on the tractor..... ...Which takes hytran..... ..Also since it has a loader on it and the system has seen some use I would drain the reservoir and clean the filter..... ....If it has Charlynn PS on it, with its own pump and reservoir you can use PS fluid, hydraulic fluid(Any) or hy-tran..... ....I have been around Charlynn systems to know one thing, if it isn't leaking it probably isn't working ;-D Will add more later, gotta run now!!!!
Kelly C
10-30-2003 19:17:55
 Re: Re: What fluid for power steering 400 rc in reply to TP from Central PA, 10-30-2003 12:10:23
It must be after market. There is a container for fluid under the sheet metal. It must work real good as mine leaks just fine. :-)
Ohio Bill
10-30-2003 10:03:43
Larry is correct. You use Hy-Tran because the factory Behlen power steering motor gets its oil supply from the hyd system. Be sure your hyd tank is where it should be on the dipstick and you are set.
Larry
10-30-2003 08:24:51
Hytran is what I use and have no problems. Don't use ATF.
