Does TA work in reverse
ftmerle
10-30-2003 08:10:48
I don't know if I have a problem or not. I was backing into the shop after just installing my new loader. When I came to the edge of the concrete something started slipping in the transmission. The TA lever was back (engaged?)so I put the TA lever forward and started moving again. Is this the way the TA works in reverse or do I have a TA rebuild on my hands. Thanks for any replies.
Red Dave
10-30-2003 08:33:44
 Re: Does TA work in reverse in reply to ftmerle, 10-30-2003 08:10:48
The TA's I have run worked the same forward or reverse. The TA is ahead of the transmission and would turn the same way going either direction.
I suggest that you get the manual and carefully follow the adjustment procedure before doing anything else. Might be enough to correct it.
Hoppy
10-30-2003 10:57:08
 Re: Re: Does TA work in reverse in reply to Red Dave, 10-30-2003 08:33:44
If you had it the lever pulled back and it was rolling down hill it will free wheel. It will also do this forward but you should try to avoid it. You problably didn't hurt anything. However alowing it to free wheel for any length of time is considered to be the fault of TA failures.
