super A stalling
Kris Johnson
10-30-2003 12:55:17
I have a 1948 Farmall Super A. Lately it has been stalling at idle and under load. It gives no warning before cutting out. It sounds OK before cutting out. I cleaned the carb and checked the screens and fuel bowl. Everything seems OK so I put it back together and I have the same problem. All passages were clear. I also tried to adjust the idle screw and it seems OK>
Hugh MacKay
10-30-2003 15:21:43
 Re: super A stalling in reply to Kris Johnson, 10-30-2003 12:55:17
Kris: How is the ignition side of tractor? Sounds like you may be loosing fire, when it hits without warning. Check points, condencer, rotor, cap. Also check the play both end and side to distributor shaft. I had that shaft loose on my SA and I say without warning it would stop, however it was usually when tractor had hit a bump, or going up and down inclines. I had distributor rebuilt and they installed bushings. I took it to CaseIH, and they farmed it out to a machinest. I believe my distributor was shorting out. It has to be very loose to do this.
Jimmy King
10-31-2003 04:29:04
 Re: Re: super A stalling in reply to Hugh MacKay, 10-30-2003 15:21:43
A coil can do that too.
