Head gasket sealant
Buster
10-31-2003 06:52:27
Hey guys, I was just told by a mechanic that if I have a steel head gasket to use the copper spray and if the gasket was fiber I didn't have to use anything, what's yalls opinion. Also if I use the copper spray do I spray the head and block also?
F-Dean
10-31-2003 16:43:16
 Re: Head gasket sealant in reply to Buster, 10-31-2003 06:52:27
Gentlemen, I keep it simple using the method my father always used - "Gun Grease." I grease both sides of the head gasket with a "Multi-Purpose" grease and torque it down. If you have to remove the head again-a common occurance for me-the gasket comes off clean and is reusable. I have had no problems using this "Original" technique.
Allan
10-31-2003 17:11:48
 Re: Re: Head gasket sealant in reply to F-Dean, 10-31-2003 16:43:16
F-Dean,
Yep, I used to use that also.
I've put hundreds of 'em together using absolutely nothing. So far, so good.
Allan
Allan
10-31-2003 07:25:09
Buster,
If you have a can of aluminum spray paint lying around, that will work equally well. Just the gasket, both sides.
I wouldn't spray the head or the block, 'cause the stuff tends to build up upon itself.
Allan
KeithF
10-31-2003 07:13:03
The mechanic is correct. Usually the head gasket box will have the instructions in it. The metal faced ones have to use a sticky sealant applied to them. It will be sold at any auto parts supply store. The fiber ones don't require it. I have used both and have had no problems. Just follow the directions on the can of sealant if you go that route.
