coil
Dutch
10-31-2003 07:46:33
When converting my Farmall to 12 volt. can I just buy a 12v coil instead of the resister thing out in the wiring?
Walt
10-31-2003 09:29:01
 Re: coil in reply to Dutch, 10-31-2003 07:46:33
Using a 12 volt auto coil on a breaker point system requires a ballast resistor in the system to save the points. There is usually a wire from the battery terminal on the starter to the switch side of the coil if you use the original starter. This gives battery voltage to the coil for starting. When running, the path is ing. switch to resistor to coil to distributor. Hopr I make some kind of sence. BTY, the resistor can be mounted on the coil bracket. Walt
Allan
10-31-2003 14:56:05
 Re: Re: coil in reply to Walt, 10-31-2003 09:29:01
Walt,
Glad to hear you say that as you are absolutely correct...I've read so many posts here that say that it isn't needed.
Now, for the guy who is going to start that tractor and move it across the yard a couple of times a year, or go to a tractor show or a parade now and then; well, he is never going to know the diffference.
But, take that same tractor out into the field and run it 14 hours a day all spring and I guarantee you that it will eat a set of points every 10 days.
That resistor is there for a reason.
Allan
Red Dave
10-31-2003 07:48:47
Yes
