Super A C Bellhousing the same?
Jerry
10-31-2003 09:03:46
Are the super A and c bellhousings the same cause I am thinking of parting a c and replacing the broken block and bellhousing in my super A.
Merlin
10-31-2003 16:50:19
 Re: Super A C Bellhousing the same? in reply to Jerry, 10-31-2003 09:03:46
I have an extra torque tube and an engine also from a 1951 Super A if you are close enough to La. to pich them up.
Stan(VA).
10-31-2003 12:05:21
Yes, but you will need to transfer the clutch and brake pedal shafts from the SA housing.
Stan(VA).
GeorgeH
10-31-2003 11:38:34
Are you referring to the (long tube) clutch housing (per parts book for Super C)?
Near as I can tell, changed part numbers at serial number 138325. From 100001 thru 138324 was 351687R71. After is 351687R8.
