Hydraulic and trans fluids H
Sam F.
10-31-2003 20:17:19
Is the hydraulic, transmission, and rear end oils all together or are they in separate compartments ?? How much and what weight of fluids. 1947 Farmall H
williamf
11-01-2003 01:48:29
 Re: Hydraulic and trans fluids H in reply to Sam F., 10-31-2003 20:17:19
The transmission and rear end both fill through the same hole, located on the right of the gear shift. ( 90wt. gear oil, according to the manual)
They have two drains, one under the pto, the other at the front of the transmission. They share a check plug, square head by the clutch pedal.
The hydraulics (30wt. non detergent motor oil) are separate, the reservior and pump are right behind the clutch. The fill is by the starter, the drain directly below that.
Wm
