154 leaking Hy Tran!
49 Cubber!
11-01-2003 08:34:10
I was out mowing my yard for the final,thank goodness,time this year.I had walked out to the barn,started it up,drove it to the house,left it running went in and ate my eggs and bacon and came back out,I had left it running to warm up a little.I put it in gear,pulled the pto lever up and away I went.I had only been running about 20 minutes total time,about 5 cutting when I noticed the smell of Hy tran.Quick look around I didnt notice anything then I hit a somewhat toguh spot of grass in my yard and looked back and the grass wasnt cut and I saw Hy tran coming out of the cover for the pto.I stopped,checked for a leak,but found none at the time.It did look as though it had been coming from the shifter.I cleaned it all up,checked the level which was low but not much,maybe a cup and took off again and finished my grass with no more leaking or mess.Any ideas as to where this may have come from and why?
