10-20 serial #
JM
11-01-2003 17:49:13
Where is the proper serial # located on a McCormick-Deering 10-20. It is approx. a 1937 model. TIA
JM
11-02-2003 05:38:02
 Re: 10-20 serial # in reply to JM, 11-01-2003 17:49:13
Thanks for the info guys
Nebraska Cowman
11-02-2003 04:00:49
JM, there will also be a number on the motor, I'm trying to remember just where. try looking on the lefthand side just above the water inlet pipe. All that being said, crawl under the tractor. The 10-20 and the 15-30 have the date cast in the bottom of the main frame casting back under the transmission. It is fairly large and should be easy to see lying on your back.
terry
11-01-2003 19:53:49
I believe the earlier models had serial # on tag under the gas tank.
