IH Backhoe
Joel
11-02-2003 02:29:27
Don't know if this is to new for this section, but I doubt it was built after '80. What would be year of an IH backhoe, 4 cyl diesel #'s 3444 and 39000-3095-P Don't know what or where those #'s are from yet. Any idea what this would weigh? Or where to find more info? Thanks Joel
Joel
11-03-2003 01:15:21
 Re: IH Backhoe in reply to Joel, 11-02-2003 02:29:27
Thanks guys. So 3444 is the model and the other number is possibly the serial number. Is there a place to check serial for year? What would be a ballpark value? A high and low. I'm checking this for my Dad who is in love with this machine and may be willing to pay to much. Or is that not possible. Joel
REDKRAUT
11-02-2003 15:57:48
Herman Brown equipment corp. handles alot of the parts for IH's industrial side
JB
11-02-2003 07:24:17
Hi, I believe these backhoes are mounted on an industrial version of the UK made B414,434,444, 384 with a BD154 Diesel. So parts for the engine & power train should be the same as the agricultural version.
JB
hal
11-02-2003 03:37:39
I had a 3444 with the 3141 hoe, it was called the backhoe special. the diesel version had a bd 154. one very strong engine. the bd stood for british diesel. to the best of my knowledge it was built around 1971-1973
ken
11-02-2003 06:41:39
 Re: Re: IH Backhoe in reply to hal, 11-02-2003 03:37:39
i have a 3414 backhoe and i believe it was built in 1962-64 it has a perkins gas motor and it was made in the u.k. and when i get parts they come from all over.needed a waterpump and it came from india if i remember correctly also had parts from south africa and new guinea.
HAL
11-02-2003 07:06:16
 Re: Re: Re: IH Backhoe in reply to ken, 11-02-2003 06:41:39
THATS PROBLABLY TRUE. BUT I DON'T THINK THEY BUILT THE BACHOE SPECIALS UNTIL THE EARLY 70S. I HAD A 3414 GAS FOR PARTS AND ALOT OF PARTS WERE THE SAME AND SOME WERE DIFFERENT. THERE WERE SOME MODELS BUILT AFTER THE 3444, I DON'T KNOW THE MODEL #S ON THEM BUT MOST OF THEM HAD WOBBLE STICKS ON THE HOE. I THINK THE 2141/3141 WAS THE LAST HOE MODELS TO USE THE 4 LEVER CONTROL SYSTEM BESIDE THE SEAT. THESE WERE REALLY POWERFULL HOES. YOU WOULD RIP TEETH OFF OF THE BUCKET WHEN RIPPING CONCRETE. YOU CANT BUY A HOE THAT HAS THAT KIND OF POWER TODAY.
ken
11-02-2003 16:28:07
 Re: Re: Re: Re: IH Backhoe in reply to HAL, 11-02-2003 07:06:16
ya mine has the 4 stick control i have seen them with short levers mine has the tall ones and man you can do some intricate diggin and power you said it i need to pull an overhaul this winter it's really puffin some smoke and fouling plugs when it does hit on all 4 man it runs so smooth.
