Disk identification
Joel H.
11-02-2003 13:45:57
I need help indentifying a disk I have. I believe it is an IH disk. The frame is made of about 3" channel iron,the frame is in two halves that bolt together in the middle. Each half frame has a cross brace made from the same channel iron. It is a tandem disk. Each gang has 9 blades spaced about 6 to 7" apart. It has hydraulic lift which consists of two small hydraulic cylinders hooked together. These cylinders look similar to what you would find on an IH front-mount cultivator or semi-mount mower. The oldest IH disk that I am familiar with is the model 37. This is definately different than that. I was wondering what model it could be and how old it could be. Thanks for any replies.
Hoosierbuddy
11-04-2003 04:57:43
 Re: Disk identification in reply to Joel H., 11-02-2003 13:45:57
That's how my 37 8 foot disc was set up-2 cultivator cylinders going into a set of tubes attatched to the lifting clevis.
It worked great until this fall,when 1 cylinder blew a seal.I took off the 2 small cylinders and went with a new 2.5" x 16" cylinder.
It lifts faster and alittle higher now!
HB
