H-350 cranks swap questions
ChadS
11-03-2003 12:50:17
Hi,, I have a question,, Can an H crank be put into the 350 block? What do I have to do to make this work? any info would be greatly appreciated. ChadS
Farmalldan
11-04-2003 10:02:10
 Re: H-350 cranks swap questions in reply to ChadS, 11-03-2003 12:50:17
Chad, Model H tractors prior to serial number 391358 have smaller bearing journals. However, I believe both rods and blocks had same bearing bore size throughout production. Thus you can use the earlier cranks in the later blocks with the appropriate bearings.
Stuart
11-04-2003 08:19:31
I dont mean to rain on your parade but if your such a big time engine man than you should know the answer to you question.
YES they are all the same crank H-350. It will fit right as rain
ChadS
11-04-2003 14:49:53
 Re: Re: H-350 cranks swap questions in reply to Stuart, 11-04-2003 08:19:31
Yeah,, I had checked on this before, but never tried it. I have worked with H blocks and cranks in the past. Not SH-350. But I really do appreciate the info. I don't know it all, but I am very eager to learn. ChadS
