International McDeering 22-36
Shane from Auss
11-03-2003 13:37:47
I am currently trying to revive a 1932 22-36. I need some info on setting up the timing. I expected some marks on the flywheel to assist with this, however I haven't been able to find an inspection cap to view the marks. There doesn't seem to be any marks on the front crankshaft pulley either. Does anyone have any info on how I might set the timing on this tractor? The oil filter element is missing on this tractor, does anyone know of a suitable substitute filter element for this tractor? Thanks for any assistance anyone might have!
Nebraska Cowman
11-04-2003 04:17:42
 Re: International McDeering 22-36 in reply to Shane from Aussie, 11-03-2003 13:37:47
the 15-30s I have seen used the same oil filter as the later farmall M
farmallmd
11-03-2003 16:04:58
pull the valve cover turn the engine over by hand until the rockers on # 4 cylinder are both rocking. that is very close to tdc, also stuff a plastic bag in the soark plug hole when it pops out it will be on the compression stroke.
