What size of motor does a f-12 have ?
James Gatzemeye
11-03-2003 21:55:37
i need to know what size a f-12 motor is i am looking for a gasket set for my f-12 i just bought. thanks James Gatzemeyer
Dave_Id
11-04-2003 07:28:06
 Re: What size of motor does a f-12 have ? in reply to James Gatzemeyer, 11-03-2003 21:55:37
113 Cu. in... 3x4, same displacement as the Farmall A, B, and C...
Zak
11-04-2003 05:52:14
Your 12, same as the 14, has a 3" bore, 4 cylinder engine. You can get a complete gasket set, or just the ones you need, from Rice Equipment. Yeah, a shamless plug, but I have bought just about one of everything from Gordon over the past 6 months doing my 34' F-12 and it came out great! Overall, it's a fairly easy tractor to work on. If you have any questions in the future, feel free to email me. -Zak-
James Gatzemeyer
11-04-2003 06:12:05
 Re: Re: What size of motor does a f-12 have ? in reply to Zak, 11-04-2003 05:52:14
Zak so what size of motor is it? thanks i will check with rice equipment
Jason
11-04-2003 09:28:28
 Re: Re: Re: What size of motor does a f-12 have ? in reply to James Gatzemeyer, 11-04-2003 06:12:05
it is a 113 cu in. becareful to go only by cu in. A 113 gasket set from napa will not have the correct head gasket for a f-12. Napa can get you a set for the f-12. I've used both rice's and my local napa. Rice comes out costing about the same as napa (even with my discount at napa). Rice has parts that are not easily obtained elsewhere. Ussally I go to napa when I need it right away, they'll able to get most of what I need overnight. If you want I can get the part number for a complete gasket set off the box I bought, just email me. good luck J
